I've got an issue I cannot seem to resolve for the life of me. My wagon has become increasingly noisy. I've replaced almost all the suspension components across the last several months. Sway bar bushings, strut mounts + front strut bearings , links, CV Axle Shafts, ball joints, wheel Hubs, rear trailing arms, struts are gas struts replaced < 10,000 miles ago.
My symptoms are a low "plop" when usually at low speeds on uneven road surfaces. I suspect a combination of front control arms (squeaky and weak) and bad struts are to blame (although it doesn't seem like it). I want to get a better idea before I shell out $400 for new struts. Need my suspension in order because I want to put new tires on the vehicle but want them to last. I got some tires previously and the suspension problems ate away at my tires to where in under a year they were no good.
