protege pully sets
blkspdfreak
03 black msp and silver p5
hey guys, i need to replace my power stearing pully. i was looking on sls performance's site and seen they have one along with a crank pully. i was wondering if anyone on here has any insight on these or any other pully sets for our cars. thanks in advance (thumb)
its not frozen or anything. is there a way to align it? i replaced the belt twice because it keeps coming off the pully. the belt is not loose, but there were some bur's on the pully itself that i filed off to make it smooth. i figured if i replace it it would eliminate the problem.
Is the pulley on straight? If the belt keeps coming off you may have a warped pulley or bent pulley shaft, but probably a bent pulley would be my guestimate
^ how do you like it? any noticeable differance? im going to just tighten the s*** out of it and see if that helps, if not then ill be ordering one monday.
how much do they run? i was thinking bout getting the whole pulley setup later down the road..
sls performance has them for like $200-$250 for the crank and alt. i seen an underdrive pully on some other site too
well i just cranked down on the belt, it might of not been tight enough. ill drive it around and see if it pops off. if it does ill talk to you about the pully nocturnal.
its all good. i marked the position on the tensioner so ill check the condition of the belt at the end of the week. no squeeking or noise coming from it, keeping my fingers crossed. thanks for every ones help
