The FSZE has the different cam. Both MSP and 2.0 Protege Sedan/Protege5 engine's are the same motor and I mean the same. Only difference is all the turbo components, MBSP, and ECU. Of course other differences like the A/C Condensor, axles, suspension, etc but you get the drift. If he was set on going Turbo on the FS motor just tap the oil pan and get the MSP turbo kit or custom make one with the same specs. Real easy to do but I rather just opt for good running MSP and save the hassle.
2.0 liter engine:
[TABLE="width: 800"]
<TBODY>[TR]
[TD]Type
[/TD]
[TD]FS-DE (US/Canada)
[/TD]
[TD]FS-DE (Europe)
[/TD]
[TD]FS-DE (Australia)
[/TD]
[TD]FS-DE (Taiwan)
[/TD]
[/TR]
[TR]
[TD]Displacement
[/TD]
[TD="colspan: 4"]1991cc
[/TD]
[/TR]
[TR]
[TD]Cylinders
[/TD]
[TD="colspan: 4"]4
[/TD]
[/TR]
[TR]
[TD]Valvetrain
[/TD]
[TD="colspan: 4"]DOHC 16 valve, direct shim over tappet actuation, timing belt
[/TD]
[/TR]
[TR]
[TD]Horsepower
[/TD]
[TD]130hp @ 6000r/min (SAE net)
[MP3 (FS9N): 140hp @ 6000r/min (SAE net)]
[/TD]
[TD]129hp (96kW) @ 6000r/min (EEC net)
[/TD]
[TD]131hp (98kW) @ 6000r/min (DIN net)
[/TD]
[TD]140hp (142ps) @ 6000r/min (JIS net)
[/TD]
[/TR]
[TR]
[TD]Torque
[/TD]
[TD]135lbs/ft @ 4000r/min (SAE net)
[MP3 (FS9N): 142lbs/ft @ 4500r/min (SAE net)]
[/TD]
[TD]124lbs/ft (171Nm) @ 4500r/min (EEC net)
[/TD]
[TD]126lbs/ft (174Nm) @ 4000r/min (DIN net)
[/TD]
[TD]138lbs/ft (19.6kgm) @ 4500r/min (JIS net)
[/TD]
[/TR]
[TR]
[TD]Bore & Stroke
[/TD]
[TD="colspan: 3"]83mm x 92mm
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Compression Ratio
[/TD]
[TD]9.1:1
[/TD]
[TD]9.7:1
[/TD]
[TD]9.7:1
[/TD]
[TD]9.7:1
[/TD]
[/TR]
[TR]
[TD]Induction Type
[/TD]
[TD="colspan: 4"]Natural
[/TD]
[/TR]
[TR]
[TD]Redline
[/TD]
[TD="colspan: 4"]6500r/min
[/TD]
[/TR]
[TR]
[TD]Alternator output
[/TD]
[TD="colspan: 4"]12V 80A
[/TD]
[/TR]
[TR]
[TD]Ignition type
[/TD]
[TD="colspan: 4"]distributor-less coil pack
[/TD]
[/TR]
[TR]
[TD]Fuel system
[/TD]
[TD="colspan: 4"]Multipoint EFI
[/TD]
[/TR]
[TR]
[TD]Fuel injector rate
[/TD]
[TD="colspan: 4"]285ml/min
[/TD]
[/TR]
[TR]
[TD]Manual Transmission type
[/TD]
[TD="colspan: 3"]G15M-R
[/TD]
[TD][/TD]
[/TR]
[TR]
[TD="colspan: 5"]Valve Timing
[/TD]
[/TR]
[TR]
[TD]Intake cam duration
[/TD]
[TD]230 @ 0.003"
[/TD]
[TD="colspan: 3"]241 @ 0.003"
[/TD]
[/TR]
[TR]
[TD]Intake cam opening
[/TD]
[TD]2 BTDC
[/TD]
[TD="colspan: 3"]5 BTDC
[/TD]
[/TR]
[TR]
[TD]Intake cam closing
[/TD]
[TD]48 ABDC
[/TD]
[TD="colspan: 3"]56 ABDC
[/TD]
[/TR]
[TR]
[TD]Intake cam lobe height
[/TD]
[TD]43.700mm (1.7205")
[/TD]
[TD="colspan: 3"]43.700mm (1.7205")
[/TD]
[/TR]
[TR]
[TD]Intake cam base circle
[/TD]
[TD]35.052mm (1.380")
[/TD]
[TD="colspan: 3"]35.052mm (1.380")
[/TD]
[/TR]
[TR]
[TD]Intake valve lift
[/TD]
[TD]8.6487mm (0.3405")
[/TD]
[TD="colspan: 3"]8.6487mm (0.3405")
[/TD]
[/TR]
[TR]
[TD]Exhaust cam duration
[/TD]
[TD="colspan: 4"]230 @ 0.003"
[/TD]
[/TR]
[TR]
[TD]Exhaust cam opening
[/TD]
[TD="colspan: 4"]48 BBDC
[/TD]
[/TR]
[TR]
[TD]Exhaust cam closing
[/TD]
[TD="colspan: 4"]2 ATDC
[/TD]
[/TR]
[TR]
[TD]Exhaust cam lobe height
[/TD]
[TD="colspan: 4"]43.225mm (1.7018")
[/TD]
[/TR]
[TR]
[TD]Exhaust cam base circle
[/TD]
[TD="colspan: 4"]35.052mm (1.380")
[/TD]
[/TR]
[TR]
[TD]Exhaust valve lift
[/TD]
[TD="colspan: 4"]8.1737mm (0.3218")
[/TD]
[/TR]
[TR]
[TD]Valve overlap
[/TD]
[TD]4
[/TD]
[TD="colspan: 3"]7
[/TD]
[/TR]
</TBODY>[/TABLE]
2.0 liter Turbo engine:
<TBODY>[TR]
[TD]Type
[/TD]
[TD]FS-DET
[/TD]
[/TR]
[TR]
[TD]Displacement
[/TD]
[TD]1991cc
[/TD]
[/TR]
[TR]
[TD]Cylinders
[/TD]
[TD]4
[/TD]
[/TR]
[TR]
[TD]Valvetrain
[/TD]
[TD]DOHC 16 valve, direct shim over tappet actuation, timing belt
[/TD]
[/TR]
[TR]
[TD]Horsepower
[/TD]
[TD]170hp @ 6000r/min (SAE net)
[/TD]
[/TR]
[TR]
[TD]Torque
[/TD]
[TD]160lbs/ft @ 3500r/min (SAE net)
[/TD]
[/TR]
[TR]
[TD]Bore & Stroke
[/TD]
[TD]83mm x 92mm
[/TD]
[/TR]
[TR]
[/TD]
[TD]9.1:1
[/TD]
[/TR]
[TR]
[TD]Induction Type
[/TD]
[TD]Turbo (Garrett GT2554RLS)
[/TD]
[/TR]
[TR]
[TD]Redline
[/TD]
[TD]6500r/min
[/TD]
[/TR]
[TR]
[/TD]
[TD]12V 80A
[/TD]
[/TR]
[TR]
[TD]Ignition type
[/TD]
[TD]distributor-less coil pack
[/TD]
[/TR]
[TR]
[TD]Fuel system
[/TD]
[TD]Multipoint EFI
[/TD]
[/TR]
[TR]
[/TD]
[TD]285ml/min
[/TD]
[/TR]
[TR]
[/TD]
[TD]G15M-R (w/LSD)
[/TD]
[/TR]
[TR]
[TD="colspan: 2"]Valve Timing
[/TD]
[/TR]
[TR]
[/TD]
[TD]230 @ 0.003"
[/TD]
[/TR]
[TR]
[/TD]
[TD]2 BTDC
[/TD]
[/TR]
[TR]
[/TD]
[TD]48 ABDC
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[TD]230 @ 0.003"
[/TD]
[/TR]
[TR]
[/TD]
[TD]48 BBDC
[/TD]
[/TR]
[TR]
[/TD]
[TD]2 ATDC
[/TD]
[/TR]
[TR]
[/TD]
[TD]43.225mm (1.7018")
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[TD]8.1737mm (0.3218")
[/TD]
[/TR]
[TR]
[TD]Valve overlap
[/TD]
[TD]4
[/TD]
[/TR]
</TBODY>[/TABLE]
2.0 liter engine (high power):
<TBODY>[TR]
[TD]Type
[/TD]
[TD]FS-ZE (1999/06/25- 2002/07/31)
[/TD]
[TD]FS-ZE (2002/08/01- 2003/10/02)
[/TD]
[TD="colspan: 2"]FS-ZE (MazdaSpeed)
[/TD]
[/TR]
[TR]
[TD]Displacement
[/TD]
[/TD]
[/TR]
[TR]
[TD]Cylinders
[/TD]
[TD="colspan: 4"]4
[/TD]
[/TR]
[TR]
[TD]Valvetrain
[/TD]
[/TD]
[/TR]
[TR]
[TD]Horsepower
[/TD]
[TD]168hp (170ps) @ 6800r/min (JIS net)
[/TD]
[TD]163hp (165ps) @ 6800r/min (JIS net)
[/TD]
[TD="colspan: 2"]173hp (175ps) @ 6800r/min (JIS net)
[/TD]
[/TR]
[TR]
[TD]Torque
[/TD]
[TD]131lbs/ft (18.4kg-m) @ 5000r/min (JIS net)
[/TD]
[TD]128lbs/ft (18.1kg-m) @ 5000rpm (JIS net)
[/TD]
[TD="colspan: 2"]134lbs/ft (18.9kgm) @ 5000r/min (JIS net)
[/TD]
[/TR]
[TR]
[TD]Bore & Stroke
[/TD]
[TD="colspan: 4"]83mm x 92mm
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]10.4:1
[/TD]
[TD="colspan: 2"]10.7:1
[/TD]
[/TR]
[TR]
[TD]Induction Type
[/TD]
[/TD]
[/TR]
[TR]
[TD]Redline
[/TD]
[TD="colspan: 4"]7000r/min
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[TD]Ignition type
[/TD]
[/TD]
[/TR]
[TR]
[TD]Fuel system
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]G25MX-R
[/TD]
[TD="colspan: 2"]G15M-R
[/TD]
[/TR]
[TR]
[TD]Valve Timing
[/TD]
[TD="colspan: 2"]Standard
[/TD]
[TD]MazdaSpeed
[/TD]
[TD]MazdaSpeed
(revised/TSB fix)
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]241 @ 0.003"
[/TD]
[TD]241 @ 0.003"
[/TD]
[TD]241 @ 0.003"
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]5 BTDC
[/TD]
[TD]5 BTDC
[/TD]
[TD]5 BTDC
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]56 ABDC
[/TD]
[TD]56 ABDC
[/TD]
[TD]56 ABDC
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]43.700mm (1.7205")
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]35.052mm (1.380")
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]8.6487mm (0.3405")
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]230 @ 0.003"
[/TD]
[TD]241 @ 0.003"
[/TD]
[TD]241 @ 0.003"
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]48 BBDC
[/TD]
[TD]48.5 BBDC
[/TD]
[TD]55.5 BBDC
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]2 ATDC
[/TD]
[TD]12.5 ATDC
[/TD]
[TD]5.5 ATDC
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]43.225mm (1.7018")
[/TD]
[TD]43.7014mm (1.7205")
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[/TD]
[TD="colspan: 2"]8.1737mm (0.3218")
[/TD]
[/TD]
[/TD]
[/TR]
[TR]
[TD]Valve overlap
[/TD]
[TD="colspan: 2"]7
[/TD]
[TD]17.5
[/TD]
[TD]10.5
[/TD]
[/TR]
</TBODY>[/TABLE]
