Product Release! CorkSport Mazdaspeed3 / Mazda3 Lower Arm Brace
Gwynne_
CorkSport is pleased to announce the release of the CorkSport Front Lower Arm Brace for the Mazdaspeed 3 and Mazda 3.
The latest addition in a comprehensive line of suspension products designed by CorkSport to strengthen the weak points in the Mazdaspeed 3 OEM underbody design, the CorkSport Front Lower Arm Brace strengthens chassis rigidity and minimizes flex by tying the lower control arms together.
Designed to fit seamlessly with the OEM control arms, this easy to install suspension component will provide improved steering control and help to maintain the alignment of the vehicle.
The CorkSport Lower Arm Brace has a stainless steel tubular design and CNC machined ends that will help to maintain a lightweight frame while adding structural rigidity. It has been powder coated for added durability and a long-lasting finish, even in extreme weather conditions.
This latest release comes on the heels of another product release by CorkSport also designed to reduce undesirable chassis flex, the CorkSport Mazda 3 and Mazdaspeed 3 Underbody 4-Bar Brace Set. This suspension enhancement links the frame to the sub-frame locking the sub-frame in place for increased control under hard cornering and acceleration.
"Immediately after I installed the CorkSport Mazdaspeed 3 Underbody Four Bar Set, I felt a difference in handling and responsiveness," said CorkSport customer, Matt Kellogg, "I saw an improvement in cornering and lap times on the track as a result of adding this product to the undercarriage of my Mazdaspeed 3. This is a great addition whether you use your Mazdaspeed 3 as your daily driver or for the track"
The CorkSport Lower Arm Brace and CorkSport Underbody Four Bar Set are available for purchase along with a number of other suspension enhancement products at http://www.corksport.com.
There is a limited number of ways to produce a part. If we are going to compared braces made all companies are "borrowing" ideas from each other. Cusco has been building braces since the 90s which means if you are applying the logic posted above then we all have been copying designs. If you want to just focus on the Mazda 3/Mazdaspeed 3 front lower tie bar, AutoExe produced their bar well before TB or CorkSport.
If you compare our bar with the TB you can see there is a noticeable difference in the builds and design. The shape is similar but we used a 1 piece bar welded to the end compared to the multiple piece welded bar from TB.
-Derrick
Thread cleaned. Only CorkSport, CorkSport Customers and Potential Customers should be posting in the CorkSport Forum as well as in their threads (same general rule applies for all Mazdas247 Authorized Vendors & Approved Merchant Members). Please keep this thread on track from now on and note that any Vendor related disputes should be handled via PM.
Everyone's cooperation and understanding is greatly appreciated, thank you.
