I had a squeling noise from the belts and I felt my alternator pulley it felt kind of greasy and I'm hoping that it is the problem. How do I clean the pulley and has anybody experienced this also
it just feels release greasy and it was clear i couldn't tell what it is tomorrow i plan on taken off both belt and cleaning all the pulley to see if it will work.
could be your thermostat if it cranked up and was running fine. i had to replace mine because it didnt open up properly. its a cheap fix like $10 most and a bottle of antifreeze unless your able to drain it first. but if its not the thermostat then most likley will be the water pump.
I would try the thermostat first. It is cheaper and easier. But just because it was just replaced dose not rule it out. I have had pumps fail hours after install just because of the quality of some pumps people buy. Rare yes but always possible.
is the squealing consistent or just sporadic or whenever you start the car?? nm you got that part fixed according too prior post. my vote is that it the thermostat. unless you got a hose that isnt fully sealed when you preplaced the waterpump.
i took of the belt for the compressor and left on the water pump belt and its the water pump belt that causes the noise also i'm running gatorback belts
