Problem with B&M Short Shift
SKY
Mazdaspeed3
I installed a B&M short shift on my MP3 since 3 years, but since last year the shifter is making noise when the car is running......there is a sounds like deeeeeeeeezzzzzzzzz on the bottom of the shifter. I live with it since it is not a huge problem, but then the noise is getting more often and louder.
I went to a garage, he see that the bushing at the bottom of the shifter is all worn.....since is a B&M shift, he doesnt have the part and he custom made a metal to attach it. Noise is gone, then 1-2 week later, the noise came back.
I went back there and he said he sealed half way of it......ok..noise gone.......but 3 weeks later, the noise came back again!!!
Anyone have similar experience on the short shifter?
its a normal "feature" of the B&M. you will ahve to live with it, or get something else.
yup! i have a fidanza short shifter which is made like the B&M and mine does the same thing. the sound comes from the pivot joint not making a perfect seal and your hearing the vibration of metal to metal. the guys with kartboy or twm dont hear this is because the stock pieces are plastic.
its normal.
ever since i installed my B&M i have this weird vibration noise when i'm on gears 4 and 5 mostly... my car ends up sounding like a tractor!
yah thats only if the bottom is hitting, i bent mine downwards so it would fit, but i still get a rattle from the pivot ball joint.
i took my heatshield off to accomodate for the resonator, no problems here
