Problem when put the transmission in D
Khaled_56
cx-9 ,2011,GT
One weak ago i change the transmission field of my CX-9 2011 , after changing when i put it in D there is click in the gear box .
I put a motorcraft Premium Automatic Transmission Fluid .
Wrong fluid. You need to get that out of there quickly. The only two fluids you can use is jw 3309 or Toyota T-IV
Our dealer doesn't sell the mazda oil ,, but I will change it tomorrow ,, but how much field it takes ,, they put 5 quarters last time
But if you are doing drain and fill only, the proper amount is about 3.3 quarts. Is your 2011 a transmission that has no dipstick? If so, search the forums for the proper way to check the level.
