SpeedBeaver
- Mazdaspeed Protege
I'm starting to wonder if the guys who installed my CompuStar alarm could've messed up something (boom07)
peepsalot said:Check the snugness of all intake/intercooler piping junctions.
Checklist:
1) Intake to turbo
2) Turbo compressor to hot IC pipe
3) hot IC pipe to IC
4) IC to cold pipe
5) cold pipe to TB
I'm gonna tell them to check for leaks...igdrasil said:You may also check the manifold to turbo gasket is leaking, start the car, with your hand close to the division where the gasket is placed, accelerate the car a few times, if its too hot, use a hose and your ear.
Yeah I know, I was planning to get rid of the cats in late spring/early summer. But that is IF they can get the car running before then. What happens if a dealer can't fix a problem? They call a "super tech" higher in hierarchy?Brian MP5T said:Plugged cat will be a constant problem.
SpeedBeaver said:Yeah I know, I was planning to get rid of the cats in late spring/early summer. But that is IF they can get the car running before then. What happens if a dealer can't fix a problem? They call a "super tech" higher in hierarchy?
Lol you know dealers, if the part got replaced and that didn't solved the problem they return it backpeepsalot said:do you get to keep the old ECU? (naughty)
