Power Steering Fluid
I cannot find the power steering fluid reservoir in the engine compartment. There is no description in the owner's manual. Can someone tell me where is it? Thanks.
Peeking into the engine compartment from the wheel well, the steering rack looks to be a manual rack with no supply lines of any kind feeding into it or any electric motor on the rack. This means the electric power assisted steering is on the steering column closer to the steering wheel.
The subaru brz/scion frs has the same set up.
