Power-House Performance Custom P5 Turbo Kit (56k=no)
wastegate is ****** up. The wastegate should only be 1 of 2 places, either right at the collector or off the first runner right at the collector.
i think that seriously needs to redesigned. The internal wastegate flapper needs to be welded shut and you need to place the wastegate at the collector.... OR just use internal wastegate :)
-b
Actaully this set up works really good. It is not post turbine. It is bleading from the original port where the flapper goes. It does not look good, but it works and other issues are that the pipe usually cracks due to vibration.
I was gonna post that too. It looks as if they removed the internal wastegate flapper from the turbo and letting the exhaust go thru the internal to the external, just like Juan said.
ah now I see it.. I just didn't notice the pipe in the pic... but yeah.... I guess this would work fine.... but I dont like the way it looks... not to mention the extra restrictions and piping for the pressure to escape... but oh well, whatever works
