Sears Exclusive
Powder-coating can be applied to iron, steel, aluminum, stainless steel, titanium, and also chrome-plated surfaces. The Craftsman Powder Coat system will allow you to obtain professional results at home at a fraction of the cost. Superior to aerosol and other liquid coatings in flexibility, corrosion, and chemical resistance. Over spray is simply swept up and disposed of in household refuse. The system includes the accessories, application gun, and detailed instructions. Powder-coating, like other high-quality coatings, can only be applied over a bare metal surface. Removing corrosion and old coatings can be easily accomplished with abrasive paper, wire brush, liquid paint stripper, or abrasive blasting. Once removed simply wipe with acetone or paint thinner, allow to dry, and coat. The only components you will need are an object to coat and an extra toaster oven or non food prep conventional oven.
Benefits of powder-coating:
Ease of application
Environmentally friendly
Fast and easy to clean up
No fumes or overspray
No harmful solvents or toxins
Very quick 10-30 minute cure time
No CFCs
EPA approved process
Required safety equipment [Items NOT included]: rubber gloves, goggles and dust mask, non-food preparation oven, electric or gas.
http://www.sears.com/sr/javasr/prod...&vertical=TOOL&pid=00917288000&subcat=For+Him
Ease of application
No CFCs
