chitownballer
Just installed my 12" Polk Momo Subwoofer running off the stock amp. I have to say this setup is REALLY impressive. Here are the sub ratings.
Specification
Polk 12" MOMO Subwoofer in Plexiglas Enclosure
Warranty:Months
Labor/Parts 12/12
Item Height in Inches 14.6
Item Width in Inches 14.6
Item Depth in Inches 11.3
Weight 34.0 lbs
Subwoofer Size 12 Inch
Impedance (Ohms) 4
Peak Power Handling (watts) 1000
Frequency Response (Hz) 20Hz - 200Hz
Sensitivity (dB) 87
Woofer Cone Material Aluminum-Clad Injection-Molded Polymer
Woofer Surround Material Hi-roll Butyl Rubber
Voice Coil Design Kapton Former
Basket Material Cast Aluminum
QTS .46
Fs - Free Air Resonance (Hz) 27.5
Recommended Amp Wattage Range Unavailable
Mounting Depth (inches) 6
Here are some install pics.. Temporarily i just hooked it up with some audio wire onto the amp without removing the whole stock sub enclosure..hopefully when i have time i will remove it. I know this sub requires ALOT more power and the stock amp does not provide this, but for now cash is scarce and hopefully i will be getting a new amp in the future..
/members/chitownballer/sub1.jpg/members/chitownballer/sub2.jpg/members/chitownballer/sub3.jpg/members/chitownballer/sub4.jpg
Specification
Warranty:Months
Labor/Parts 12/12
Weight 34.0 lbs
Impedance (Ohms) 4
Sensitivity (dB) 87
QTS .46
