Pics of the 505 MSP
putting the amp on the back of ur backseat makes it vibrate like crazy and will mess it up over time, my us acoustics is now screwed becaus ei had it screwed to the back of the seat
How and what did you paint it with? Since it was so high gloss finish I can imagine it was a pain in the ass to get painted.
Matt
REALLY nice car man. where did you get the indiglo gauges from ? exactly the look im looking for
Matt
Im talking about the hood vents if you did not know which is a good possibility because I did not specify.
Matt
505zoom said:
dominoy2k1 said:
did you break any of the needles?
Thankfully, no. I thought the tach was going to break, but then the overlay just kind of snapped over the base, lol.
Did you cut the gauge in order to place them without removing the needles !?
I found the look pretty cool and I have been wanting them for a while, but Im too afraid to brake a needle while installing them and nobody knows how to remove them safelly :( !!!
Matt
I used a mouse sander to rough up the surface and then cleaned with soap and water. Then I used a automotive primer, 5 coats of metallic black spraypaint, then 3 coats of clear.
Thanks man, I got them from procarparts.com
Titanium-99 said:
Question? how can i get those blue lit gages and what dose it take to install?
Like I just said, I got them from procarparts.com, and they are fairly easy to install. You just need to be careful to not break a needle.
Matt
I painted all of the mesh with the same paint.;)
You can not remove the needles. I did make small cuts in the overlay to help get it on.
