pics of spool springs on my MP3
PaulMP3
Contributor
Turbo MP3 #222, 00 Silverado Z71
here are some pics. I installed them yesterday, as u can see the weather is very wet. I took these pics as soon as the rain stopped. I'll take some more once it settles a bit more, and it washed up.
http://www.mazdamp3.com/members/paulmp3/117-1744_img.jpg
Seems the difference isn't huge compare to the stock springs, especially the rear. How much drop is that?
Looks good;)
Its a 2 inch drop, any lower and you will degrade your ride comfort, handling and suspension geometry. These are lowest one could go with the stock shocks
Sky, i agree with you. From the looks of spool springs, the back height compared to stock is about the same. The front on the other hand is definetely lower then stock by at least an 1".
How is the ride?
I think it looks perfect, once you have 2 passengers in the car.
believe me it is low. the pics dont do justice. I took b4 pics with a tape measure. i will take some after pics once it settles to see what the actual drop is. I think it looks dope.
I suggest after the springs settle, to tighten the dead center bolts on the top of each strut, but only if you develop a squeak, which this will cure. =)
enderFound said:
I like the drop(2thumbs)
The drop looks even to me.
its is very even i was expecting the back to be higher. the first pic is the best one b/c it is from a normal point of veiw. I think ill let them settle a few more days b4 aligning them. i had like 200lbs last night. i will probally put it back in 2 night.
thanks, i read ur thread about this problem u had. i will keep my eye on it.
