Pics of my rear subframe on ground!
I had my rear diff mount and bushings installed here are some pics of the rear sub frame on the ground. I also had this done cause I had to replace the upper bushings for my HSD coilovers it is hard to get at the bolts to replace.
Might I ask where you got the diff mount? I understood CP-Es was not yet available, so I am assuming this is someone elses?
