Hey guys, it's been a while since I posted, but I haven't stopped working on Scruffers. First, something minor:
It's a Delrin shift knob, intended for a Miata. Although I really do like the stock shift knob, the metal plate on the top gets really hot if the car's been sitting out in the sun (and I'm sure it'll be really cold in the winter too). So, I decided to swap it out for this. I don't do leather, and I didn't want a metal shift knob, but I
stumbled across these knobs on ebay. They are inexpensive, very strong, have a nice heft to them and are really comfortable plus they come in a few different shapes. This one is very close to the stock shape and size. Perfect! I don't know if it's a placebo effect or not, but the car seems to shift better with the new knob. Also, it comes in a bead blasted finish, but it's gradually self-polishing from use, which I like. The only thing is about this knob is that it's not an exact fit. Oh, it screws on just fine, but it leaves about an 1/8 gap or so between the bottom of the knob and the top of the shift boot. I solved this problem by inserting a black rubber grommet and a stainless steel washer between the shift knob and the shift boot and it fits perfectly. The grommet isn't noticeable at all and you can't see the washer either. I can post a pic of the parts if anyone is interested in doing this themselves.
Now the major news is that a couple of weeks ago, I set out to strip the upper rocker panel on the driver's side because it had surface rust that was very poorly repaired, as shown:
Well, upon stripping this area, I found that things were a lot worse than I could have possibly guessed. I really had no way of knowing beforehand, but there was literally pounds of body filler applied to the rocker panel. It seems that there was an impact to the rocker panel, and it must have caused water to become trapped in there and rust it out. The body filler was simply applied over the rust. (hand) Here's how it looked once I stripped it all:
Ugh. Not pretty at all. What I did was I cut out as much of the bad metal as possible, treated it all with Eastwood's Rust Converter and Rust Encapsulator, and fabbed up a patch panel welded to a reinforcement strip that sandwiches the bottom seam of the rocker panel for reinforcement. Here's the rocker panel partially treated with one coat of the Rust Converter:
And here's my patch panel and reinforcement.
I made this patch panel from a sheet of 20ga steel that I scavenged from a metal fabrication business' dumpster, and two 4 foot long piece of 1/16" thick flat steel stock that I bought. I welded the patch panel to the steel flat stock and that bolted on with stainless steel hardware to the bottom rocker panel seam. The seam is sandwiched between the two pieces of flat stock to reinforce it after being weakened by the rust. Obviously, the patch panel is blind-riveted on. I hope this will hold together for a while. After this, I painted over it all with Eastwood's Rust Encapsulator, then Eastwood's Rubberized Rust Encapsulator and black seam sealer. Yes, it's ugly, but my repair is not visible at all with the side skirt back on. Sorry, no pics of that right now.
Unfortunately, I got into trouble with my condo association for working on the car outside. Apparently one of my neighbors complained to the association (they never even approached me), and the association basically sent me a cease and desist order.
I'm apparently not even supposed to work on my car in my own garage, even though I've been doing so for years now without any issues...until now, that is. I also got in trouble because my GLHS is not registered. As of yesterday it's now registered, so that will get them off of my back for a while. I'm starting to explore my options now since I can't work on my car at my own place anymore, that includes everything from renting a garage to finding a whole new place to live. It sucks, but that's life. I'll figure something out.
