Perrin Intake installed!!! Whoo Hoo!
Laser Blue MSP #2733_sold
This intake is very nice. However; installation is kind of odd. But it works. I'm using the apexi intake power intake filter because I'm not a fan of oil type filters, which is what the Perrin filter is. The sound is nice also. You can hear the sucking of the air and spooling of the turbo much more, due to the Perrin being so short. Also; the diverter valve (turkey) is louder. The only weird thing is the engineering of it. Maybe a Perrin person on the forums can help me on this one. The MAF is sort of in the way of the diverter valve, and I had to buy a 90 deg. piece to have the back part of the diverter tubing not be bent. If you have a turboxs diverter valve, you should not have this problem. All in all, it's a very nice intake, good material.
product looks good but what do you mean by "oil type" filter? isn't the apex one a cotton gauzed one too? do you mean foam type? foam filters are actually supposed to be better flowing then cotton gauze type (stainless mesh would be above that on the list) but do filter less particles then a cotton gauze type. this is one reason HKS uses dual layers.
HKS is one of the worst... check this out < http://mkiv.com/techarticles/filters_test/2/ >
The Perrin filter comes with lots of oil on the foam part of the filter. Dirt sticks to the filter, thus clogging it making it harder to get air taking away performance. You may clean it and re-oil, but I prefer just to have a filter such as the apexi, my preference.
Nice... does your car stall when you are like in idle by any chance? And was it kinda weird to install?
ok check it, the bypass fitting on the perrin intake may be causing air turbulance in the maf sensor body thus giving the pcm a jacked up reading. the turbulance causes vaccume and the maf reads 0, thus screwing you over. this is my hypothesis.
interesting.... Yeah cause it's like when you "blow off" (divert) and your in neutral, the RPM's drop and stall the engine. Did you get yours yet
you know, i had a feeling this problem would arise with that type of positioning of the bypass nipple. i didn't wanna say anything cuz it might have been a nonissue. there are a couple of other people having the same problem as you. i'm actually glad that i didn't go off my impulse buy notion on that thing. it's the same problem injen had a year ago. the solution is to move they bypass nipple further down, or, maybe just angle it towards the turbo. that MIGHT fix the problem with the turbulance.
Worlds Longest Post
starflare21 said:
i guess that vacuum cleaner test on that website beats the stuff i've heard from a friend that has an engine dyno. (dunno) go figure
good article.
Hey guys,
Let me give you some facts about filters .....and then let you decide.
Basic overall issues
Free flowing filter = no dirt filtration
Ultimate dirt filtration = no air flow
What most people want falls somewhere in the middle. Good filtration and maximum power.
Metal mesh filters catch nothing. These filters are like a screen door for your intake. The benefit to these filters is scene at the track. You want as much flow as possible but you don't want to ingest something from under the hood by accident. These filters are not recommended for daily use if you are at all concerned about engine life.
Cotton and gauze mesh trap dirt in a layer of gauze sandwiched between two metal screens. More expensive name brand versions use a higher quality gauze layer compared to cheaper filter copies made overseas. The higher quality gauze traps more dirt but also hinders airflow.
Foam filters
Multiple foam densities and the use of dual and triple layers can make generalistic comparisons difficult. The basis of the design is that you have approx an inch of filter material. The material filters by suspending dirt in oil which clings to the mesh matrix of the foam.
Additional facts
Turbo charged vehicles ingest as much as 10 times the amount of air. This means that the filter has to filtrate 10 times the amount of dirt. This also means that because of the enormous sucking ability of the turbo air turbulence is not a factor.
PERRIN Performance made a choice to step away from main stream filter design/choice. Our experience designing parts for supercharged and turbocharged vehicles has led our company to choose the foam filter design. Our first priority is air filtration. We feel that we offer foam filters add the perfect blend of power and protection for turbo charged vehicles. We will fully admit that you can achieve even more horsepower using a higher flowing filter with your PERRIN intake systems. Our company has chosen a filter product, which we feel, offers superior filtration and excellent power gains. (2thumbs)
As for the MKIV test.
The test seams flawed to me here.a few reasons why.
#1 how were the dirt particles introduced the filters. I see they used a vacuum as the suction source. I can only imagine that they just sprinkled dirt on the filters.
#2 the particular foam filter used here is only about 3/8th of an inch thick. It is only intended for race use and (though noted at the bottom of the page) it does not come coated with an oil media.
#3 there is a distinct flaw/irony when the cotton and gauze filter, which indicated that it trapped all the dirt, also generated the most horse power. Why would either the metal mesh or the foam filter, which obviously allowed the most flow through, not have the largest increase in power?
#4 the last Irony is that foam filters are classically accused of being way to restrictive. This leads into the next point..
This excerpt is pulled direct from K&Ns web siteIronically saying the exact opposite of the MKIV test.
www.knfilters.com said:
Typical foam filters
#1 Lack of surface area hinders air flow and dirt holding capacity. Open cell foam usually saturated with oil.
#2 Dirt builds on outside and blocks the openings.
#3 Higher vacuum pressures distort the cells drawing dirt deeper into the filter.
#4 Airflow is reduced as cells become blocked.
This is miss information too.
-Though foam filter have a smaller outer surface area they, unlike cotton and gauze filters, can trap dirt anywhere within the entire thickness of the filter. The working area" of the filter is actually much larger then cotton and gauze.
-#2 is laughable. I think that this must be a misprint. This is actually a flaw with the cotton and gauze filter. As the filter gets dirty the dirt blocks pores reducing flow. Because a foam filter traps dirt within the entire filter it will have the same flow rates after thousands of miles of use. Even in extreme dirt situations.
The point. Finally
We do not manufacture air filters. We have air filters custom made to our specifications based on the vehicles we manufacture parts for. Every style of filter is available to us as options for our company to use. I hope that the information I have laid out above reinforces our choice to use foam filters. Very high rate of filtration, good horspower number, and a new distinct look. We have made the decision and will continue to use foam filters with our products.
If you have any further questions or concerns our sales staff would be happy to speak with you.
PERRIN Performance
1.503.643.4677
Ps. Since i started writing this response this thread has grown. I will answer try to answer all of your concers tommorro.
cheers.
(cheers2)
I am curious why they decided to leave the Cone Filter mounted infront of the Engine Fan.
Blowin that hot air onto the intake..just don't sound like you would get good gains..
Chas
Chas
b/c their frontmount is so huge and efficient that it doesn't matter wtf temp air that thing injests.
By my calculations, you would need about 132 lbs of boost to ingest 10 times the amount of air. Yeah, I suppose a turbo could theoretically produce 'as much as' that amount, but we are talking protege's here. On MSP stock boost(~6.9), it is close to 1.47 times as much air. I think perrin is a great company and I appreciate your support of the mazda community, but lets try to keep our facts straight.
