Performance partout and much much more!!!
Phenolic TB spacer with hardware - 35
New civic aluminum half radiator with cap – 70
99-03 white hood – 75
MSP headlights (need cleaning) – 80
Turbo Parts:
New HKS 3.0” pipe – 25
Large FMIC with 3.0” inlet/outlet – 100
New 255 lph in tank fuel pump – 50
(with injector pic)
Will the SX Performance rising rate AFPR with autometer pressure gauge, an 6 line, fittings and special rail adapter work with the Perrin Fuel rail? If so I am interested. Also is that a pic of the LSD still in the tranny?
Rob
The lsd is in the trans. I will sell the trans as a whole or I can take the lsd out. I can take a better pic of the adapter but it attaches the same way the stock fpr does. So if a stock fpr works, then the adapter will too
If the guy for the red valve cover back out would you take $110 shipped to canada?
And how much you want for the 626 intake shipped to canada?
The red valve cover is pretty much sold. Id have to get a quote. Shouldn't be more than 40 to ship the 626 mani
Hi, I'm interested in the Innovate wideband. Is it complete with Bosch sensor and data cable/CD? Which faceplate color? How much would it be shipped to Germany (usually easiest with USPS)?
The innovate is currently pending. Look on ebay and you can get a steal of a price. I paid like 183 shipped brand new in box from a vendor
Someone buy this polished and ported fuel rail, fpr, welded lsd, awr oil pan, 626 mani and large intercooler
Hey mate,
i sent payment for the Signature Cans on the 6 Nov 2011 and haven't heard from you since. Can you PM me the tracking number at least?
Cheers
I've been trying to message you through google talk. Parts were shipped. PLease pm me with any questions
bump. still have 626 manifold, awr deep sump, tb spacer, afpr, lsd, oil cooler, large FMIC, poly motor mounts, msp headlights and more turbo stuff!!! willing to work payment plans and package deals. dont be scared to make an offer!!
The following items we have agreed to a payment plan and deposit has been paid:
626 manifold, painted, ported, egr block - 100
New black oil cooler - 50
Reworked MAM ramhorn manifold (t3, 44mm v-band wastegate flange, ceramic coated, fireball coating inside) – 400
Tial polished 44mm wastegate with spring, dumptube, and v-bands – 250
Holset hy35 with welded wastegate flapper, 4” inlet, 3” outlet (with custom DP flange) – 250
4an oil feed line with special fittings for holset – 35
10 an drain line and fittings for holset – 35
New K&N 4” intake filter – 35
Yudkib custom vacuum block - 20
(2) 3.0” stainless U-bends and bellow for custom DP - 100
SX Performance rising rate AFPR with autometer pressure gauge, an 6 line, fittings and special rail adapter- 150
Turbosmart Black Boost Tee controller – 50
Acid ported and polished fuel rail, fits 626 manifold above, with an 6 fittings – 70
Do you have the harnesses leading to the headlights? I've got a p5 and switching to sedan lights but need the wiring.
