chromoly bearings?!?!? What the crap bearings are you talking about?!SPOOND said:Can anyone tell me where i can get good chromoly or teflon coated bearings for the 2.0 fs motor (protege)
whered you get them from and where did you send them to get coated? also how much were they before and after coating??ddogg777 said:hee hee, you should know not to take stuff seriously from me, just see my sig...Chromoly is much too hard of a metal for the bearings to be made of. They are designed with softer metals similar to bushings.
The HP main and rod bearings are Toga: http://www.autoperformancewarehouse.com/toga.html
I sent mine to a techline coater and had them coated with a dry film lubricant designed specifically for the bearing surface (kinda like teflon I guess).
