S sleeperms6 Member : 2007 MS6, black Mica May 22, 2011 #1 Just put my boost gauge on And I was wondering how much boost should I be at with just a Cobb intake? Is it 15psi?
C CodyReagan May 22, 2011 #2 Yeah 15 is the correct number 15.6 to be exact but 15 is about right, shouldn't be going higher than that though.
Z zinger002 Member : 2006 Mazda Mazdaspeed6 May 24, 2011 #3 anything between 15 and 16 is good depending on temperature and other factors. But thats a good number.
0 07mspeed Member : 2007 mazdaspeed6 gt Jun 16, 2011 #4 how do you make morwe boost on a stock ms6? is it just a tune?
Z zinger002 Member : 2006 Mazda Mazdaspeed6 Jun 20, 2011 #6 stay away from a mbc. the small turbo and quick spool characteristics can create massive boost at a low rpm. this has been proven to cause blown motors in this motor. if your not careful or without a built motor you will regret it.
