No. They will be worse! Less surface area, and, to boot, more likely to crack!
Cross-drilled was made a long time ago to deal with brake pad gassing ... an issue that is no longer relevant. Slotting sometimes is used to clean pads on rally cars, but that is not an issue on the pavement.
If you want to upgrade your rotors, get larger / thicker ones, if there are any that fit.
Most people should just go to the track first to figure out what there car needs, not have to guess. You can go a lot faster by improving the driver before improving handling or power. Braking is always important, and good to have, though.
Edit: Also, if you run all-season 40,000 mile style tires, they will probably heat up first. If it's rated as "Temperature A" it will probably be OK.
