- -- 23 CX-5 --
If you can see oil buildup around the timing cover then I would suspect cam seal leakage, crank seal leakage or both. Neither of these would be good for your timing belt if they are indeed leaking the amount of oil you are going thru. There's probably a mess inside the timing cover. How many miles on the car? Depending on that, maybe the timing belt/tensioner/water pump/cam seals shoulda been done when it was apart to change the head gasket. The belt is a 100k mile thing, the others are just easy to do while in there so you don't have to go back in there any time soon.
If you're car is actually trying to burn that much oil, the inside of your tailpipe will be very carbony but dry. If it is pushing as much as you are losing then the inside of the tailpipe will most likely be very carbony but not dry, but nasty slimy instead.
