Check engine light is on p0171 have freeze frame data?
Ok have a Mazda protege 00 1.6l and the check engine light is on for p0171 which is system to lean, before i have to this code though 1 month ago i had a check engine light p1170 for a 02 sensor but the code was intermittent and then p0171 came on but the p1170 cleared and never came back when i reseted the ECU but the p0171 code came back and only that code. The car starts perfect every time, it just idles rough not that bad on a cold start, but it shakes pretty rough at idle when car is warm. I did the MAF test by removing the MAF sensor and starting the car and the car started but died instantly and i unplugged while the car was running but the Idle seem to have gotten worser. Also i cleaned the MAF sensor and it still idles rough I sprayed carb cleaner on the intake manifold and all the vacuum lines egr etc and no vaccumm leaks.
Here are my frame data results from my obd2 scanner:
Fuel Status = 0 byte
Engine Load = 47.451 %
Engine Coolant Temperature = 192.2 F
Fuel Trim Bank 1 Short Term = 12.5 %
Fuel Trim Bank 1 Long Term = 25 %
Engine RPM = 2,302.5 rpm
Speed (OBD) = 29.826 mph
what could be the problem
also car runs on closed loop and not open loop.
Also changed PCV valve, air filter, spark plug and wires and coils and still have rough idle.
