Optional tire sizes for winters
Slayer33
2012 Mazda 5 GT
Just researching winter tire options for my 2012 Mazda5. I know the stock tire size on my GT is 205/50R17 and the base models have 205/55R16s.
I'm looking to get a set of rims with tires, so I will get 16" wheels and tires. I don't know if 15" wheels/tires will clear the calipers.
If I go 16", does anyone know if it is so bad if I went with 205/60R16 over the 205/55R16 stock size?
The tire would be about 2.4" larger in diameter than the stock 17s, but I think it would give me a little more cushion as well as a bit more groudn clearance.
Anyone know if this size is ok? or should I just stick with the 205/55R16 size?
You must have been doing the math wrong... 205/60-16 is only 25.7 inches, which is barely larger than the stock 25.0 to 25.1 inch tire. You'll clear the wheel well fine. You could go with 195/60-16 (25.2 inches) also if you don't want to crowd the top of the wheel well.
sorry, didn't mean to say 2.4", actually meant 2.4%.
A 195/60R16 might be the best choice since I'd prefer to have skinnier tires in our winter climate..
Unfortunately there aren't very many options of tire in that size :(
205/60 or 55 series it is.
I used a set of 205/60/16s this "winter" on my Sport and it was fine. The speedometer was off so I used my GPS to watch my speed on the highway because the cops are thick on my commute and have quotas to fill. No problems otherwise though.
we are running 205/55-16 winter tires on our 2008, and they work just fine.
Gotcha. I run 255/40-17 all around with almost no tread grooves on a 2800 pound car for winter here... but I'm in Texas. :D
So does anyone know if a 15" rim and tire combo will fit on our 2012 5s? This would be the most ideal size for winter, but I can't find anything online that says it would fit.
hmmm this would be awesome if a 15" rim would fit on my 2012 5. I wonder if the JDM and EDM spec Mazda5s have smaller brakes than ours? That would be the difference in whether or not they would fit.
Don't know if you were still looking, but I have a set of stock 16s I took off my 2012 Sport... will post in the classifieds.
Over here in The Netherlands, 195/65R15 is the standard wheel/tire size for the 2012 Mazda5, my 2005 Mazda5 has them too.
New Threads
