ok i have two ?'s maybe some1 knows
first ones is has anyone had problems w/ their shocks? i keep hearing this nasty sqeaky sound like if theres a leak, but the dealer says they dont hear anything..... right just dont want to replace it. and now its gotten worst that the cold is hitting, it sounds like its about to break on me. they say since they r sports shocks they will make a dif. sound but i dont think it should be like the sound i hear now and as loud... wat should i do or say to them ive gone there 2x already.... and now the other ? is does anyone know where and if i can get a billet grill, ive only seen it on one p5 and to me it was sweet. so basically i want it hehe no one in md would have it... i hope...any help on either question?:confused: :(
That sounds like it might be your sway bar bushings if it isn't the shocks.... If you think this might be the case, try taking off the sway bar and grease up the bushings real well with some synthetic grease. I don't know about the grill... Anyways, Good luck!
Bushing Squeak
I have always used a penetrating lube on suspension bushings when I change oil. I have been using Mobil1 Spray Lube on the bushings of my cars for quite a few years. I just spray a bit on each side and let capililary action bleed it in around the bar or bolts. Many years ago, the standard procedure in the garage I worked in was to lube the bushings with ATF when we did an oil change. Jim
yeah well they did replace the bushings but the sound is still there and like i said it sounds worst. i hate it.!!! oh well i still have warrenty and i will find a way i didnt pay for it for nothing well the extended 1 that is. but thank if any one knows about the billet grill let me know thank again
