Ok guys, I have parts coming for 20 kits on Tuesday. The check valve is a different one than I have been using, it is a much higher quality. But as with all changes, I want to do it to my car first. If it works the same (as it should), I am giving this an all clear.. You can start to order whenever you want (the sooner, the better to cover my expenses).. The price will be $25 including shipping. For $25 you will get-
1) 3/16" ball and spring check valve
1) 3/16" hose tee
3' of 3/16 hose
1) 3/16 90 degree elbow
1) rubber grommet
1) 5/16" drill bit
1) instruction manual
all shipped to your door...
Without going too much into detail- the checkvalve tees into the FPR line to reduce the amount of boost going to the FPR. It then has a return line from the check valve that goes to the air intake hose (hence the drill bit, elbow and grommet).
Before people start saying "bleed the boost going to the FPR- WTF?"- this car runs ABSURDLY rich up top, I have never seen a stock car dump so much fuel in my life!!! I have bled off a hell of a lot more than this and was still richer than I would like!!! This kit in the couple test cars has lowered fuel pressure enough to make the car run more consistent on hot days without falling on it's face- yet remain very safely rich..
While I am more than confident based on over 1000 miles of testing that the kit is safe for all conditions, I would prefer the first few orders come from people with AF gauges just so they can monitor it for me.. If I hear of anyone runnig too lean, I will let you all know of the problem. I seriously doubt that will be an issue however- my car has been in FL on mid-90 degree days and up here in NY where it has been upper 40's at night with no adverse effects at all- I am just trying to play it safe
I hope you guys find the price fair enough for what you get, it is about $17 worth of stuff including the drill bit and I am doing your shopping, R&D and packing for you
.. If you feel you need to copy it to save yourself the $8 and do all the running around for yourself, have fun- you unoriginal, can't figure anything out for yourself bastard
I am now accepting orders- my paypal address is sales@joepmbc.com
If you have any questions, either reply here or shoot me an email at kwiktsi@nycap.rr.com
ONCE AGAIN- this is not a cure all for all the tuning issues or stumbles that this car has, but it GREATLY improves the 4500 switchover stumble under boost and keeps the car from falling on it's face up top.. It is recommended that you at least have a K&N filter for increased air flow though, but it is not 100% necessary.
Thanks.
Joe
PS- Once I get the supplies on Tuesday, give me a couple of days to get the instructions written up (I am starting tonight, but need the kit here for reference purposes for me to finish them).
1) 3/16" hose tee
3' of 3/16 hose
1) rubber grommet
1) 5/16" drill bit
Thanks.
Joe
