Oil pres and temp gauges?
I just installed my BP gauge and have the oil pressure hooked up and trying to find the answer for the sender hookup now. If I find a solution I will post it.
Either locate the stock sender and yank it, replace with your new sender that you can trust or run a T connector off the stock sending unit and add the new one. I dont recommend trying to use the oil filter sandwich adapter if that was an option you were thinking about.
