Oil pan gasket seal
limey
Mazda Protege LX 1999
My mechanic tells me that my oil pan gasket seal is leaking and needs replacing - is this a relatively easy job that I could do, or should I pay my mechanic big bucks to have him do it?
I have a 99 Protege 1.6L engine.
It's not hard at all , and you get to get your oil change out of the way. Just make sure you use gasket maker on the corners
Gasket maker? There is some silicone sealant in the kit if that's what you mean?
