OFFICIAL word from Mazda on the RX-8 and dyno tests
shaolin
MSP-->RX8-->Something big, quick, and German
<TABLE cellSpacing=0 cellPadding=6 width="100%" border=0><TBODY><TR><TD class=alt2 style="BORDER-RIGHT: 1px inset; BORDER-TOP: 1px inset; BORDER-LEFT: 1px inset; BORDER-BOTTOM: 1px inset">Statement:
There is no true way to generate flywheel horsepower from a chassis dynamometer because of frictional losses in the driveline, clutch, transmission, differential and tires. Also, variations in testing procedures will cause highly disparate readings: open/closed hood, high/low humidity, high/low ambient temperature, tire pressure, how tightly the car is tied down, which gear the car is tested in, etc.
In addition, we have determined that, in order to prevent damage to the catalytic converter and the entire driveline, when the PCM determines unusual operating parameters such as excessive slip in the drivetrain from the front to the rear wheels, it causes a rich high-RPM mixture and retardation of the timing. All these items combine to cause apparent considerable horsepower loss.
BACKGROUND:
Horsepower Measurement
There is only one true method for measuring engine horsepower: on an engine dynamometer at constant speed and utilizing variable load.
The engine should use the same intake and exhaust system as in the car. HP results must be corrected to SAE J1349 standards as listed below:
77 degrees Fahrenheit
Sea level
0% humidity
Correction factors must be applied to reference the measurements to SAE J1349 standards. Any correction factor beyond 7% is considered invalid.
Chassis Dynamometers
SAE has produced a technical paper (SAE Technical Paper Series 2002-01-0887) that attempts to address the ongoing debate about inertia dyno horsepower versus OEM net horsepower. You can order a copy by visiting their website at www.sae.org -- we have no intentions of getting mired in the middle of this discussion.
Bottom line: If used properly, chassis dynos are great tools to assist with tuning and modifying vehicles. It is impossible to measure the actual flywheel horsepower because there are simply too many variables.
Other issues that are unique to the RX-8:
The RX-8 uses a very advanced engine management system. Besides precisely controlling the operating parameters of the engine, self-preservation (of both the engine and the catalytic converter) is also considered.
The engine management system continuously monitors all engine functions and adjusts accordingly. For example:
Under heavy load acceleration, the timing is retarded and the fuel mixture richened to reduce the likelihood of pre-ignition or spark knock. If spark knock is encountered, a knock sensor senses the condition and further retards the timing. Gradually timing is advanced and fuel mixture leaned after the load is reduced.
A second reason for fuel enrichment is that when timing is retarded, exhaust temperatures increase; a richer mixture lowers the exhaust temperatures and reduces the chances of damaging the catalytic converter.
In real world driving, this all goes unnoticed to the driver and appears seamless with no disruptions to the performance of the engine. The car encounters a load under acceleration but the load quickly diminishes as the car accelerates in each gear.
Operating on a chassis dynamometer, however, creates a completely different environment. Inertia dynos use a known mass that is accelerated to measure torque at the wheels. This is usually done in one gear under heavy load conditions:
Only the rear wheels are turning while the front tires remain stationary.
On cars equipped with DSC with traction control, the difference in speed between the front and rear wheels is sensed and the power is reduced immediately to compensate for what the car senses as excess wheel spin.
If the DSC is turned off, the traction control is disabled but the brake functions of the DSC are still operational.
If the DSC system is completely disabled, this removes the brake functions from the equation, however it does not fully remove the engine management system functions.
The ABS hydraulic unit/control module (HU/CM), or the DSC HU/CM for cars with DSC, determines vehicle speed by comparing the speed of all four wheels. If two are turning and two are stationary, it will still compute a speed but senses that the car is experiencing excessive wheel spin. To protect against engine or catalyst damage:
The engine management system compares the throttle opening, gear selection (determined by engine speed and road speed) charging efficiency and engine coolant temperature to determine the driving condition.
Since the car is under heavy load, in a tall gear (testing is usually performed in third or fourth gear), with a wide throttle position angle (wide open), spark timing is reduced and the fuel mixture is richened to reduce the occurrence of spark knock and to reduce catalytic converter temperatures.
</TD></TR></TBODY></TABLE>
This came from rotarynews.com
Cliffsnotes: The car when being dyno'ed senses that the front wheels are not turning and essentially goes into "safe mode." Even with DSC and TCS turned off it will still sense abnormal engine use, and possible abuse and changes fuel maps and timing to reduce wear on the powertrain and emmisions control systems.
This same problem is also being experienced by BMW M3 and Porsche C4 owners.
yeah I think the motor HAS to make more than 238hp...I've driven them pretty hard and they pull like mad. MUCH harder than my 250hp mustangs.
More than 238? I dunno. This statement was released to address the growing concern of RX-8's only dyno testing 160-180 HP at the wheels. Which would only equate to about 215-220 crank horsepower, which doesn't make sense because the car still performs as it should given the stock numbers.
So this is a viable explanation of why the cars are dynoing so low. The RX-8 is one of the most electrically and technologically advanced cars out there. It's basically self-aware. It senses that the front wheels arent turning and basically detunes itself. Smart car? yeah. Pain in the ass to dyno test though...
Spooled said:
An engine with a wide torque curve will pull harder. Peak HP means very little.
Not necessarily correct. You will feel more acceleration at your peak tq than your peak HP(turbo cars are an acception due to turbo lag). It's better to have peak tq in the high rpms to make use of gearing as opposed to a wide torque curve.
Most definitely. It would suck to have your peak power at a low to mid RPM, and have the rest of those revs for no damn reason.
