oem remote start problem
I have a 2008 mazda 3 GT automatic 5door. Recently my remote start has failed to work for me. When I try to initiate the start up it chirps and flashes the lights twice. In the owners manual it say nothing about what the code means. and I have search the web looking for answers. The only thing I found was that the current models it means the brake is pressed or key is in the ignition and unless my ingition cylinder is dirty my key sense circuit should not be active. I did recently change the battery, but I do beleave I have used the remote start feature since then, but the last time I used it was in quick stop mode and when I returned it would not let me unlock the car, so I had to unlock useing the key which set the alarm off. Any help or advice will be appreciated. Thanks
