The other day I noticed that my A/C was not cooling as good as it has been. I did some listening and checking and it seems that the A/C cools better if it's running at an idle. If it's running or I'm turning up some RPM's the air warms up. I brought it to a shop and they said that they put some R134 in it. It was after this that I noticed that it's not cooling while running. Do these cars have the expansion valves or resevoir. <sp?> Do you think I should take down the whole system and recharge it?
BTW, the ambient temp is close to 100F. The temp out of the vent on low and outside air is about 44F idle, 60F while driving.
