O2 Mod Unit
little bit off topic but i noticed in the pic for your intake setup that you had 2 pipes connected to each other and then the MAS/filter. did your stage 1 spool come like this? i'm starting to notice a lot of things either missing or parts/fittings/pieces being the wrong ones more and more as the car gets closer to completion. kinda depressing. I think i might be one of the few thats getting bad luck from this project :(
No I added a peace of 45 deg. pipe so I can make my own coldair intake.
Once you get everything install ,The next thing is trying to get the bugs out.
Ok from the horses mouth.
There have been alot of changes with the wiring setup of the 02 modifiers in the past few months. I was going on older instructions and was unaware that there was another update. So the instructions on FM's site are the correct ones. I am back in town so if any of ya'll have any questions you can call me and I would be more than happy to help out:)
No that is an add to our kit, it did not come like it....I sent you an email:)
There have been alot of changes with the wiring setup of the 02 modifiers in the past few months. I was going on older instructions and was unaware that there was another update. So the instructions on FM's site are the correct ones. I am back in town so if any of ya'll have any questions you can call me and I would be more than happy to help out:) No that is an add to our kit, it did not come like it
and then there was peace...and all was good. good old Terry.
Hold on there smokey, there were 2 changes. I only remeber 1 wire being wired backwards? Was that it or is there more?
I opened mine. . .yellow and pink wires that follow the spool instructions perfectly, but if you don't have a pink wire. . .you're on your own. :D
