NOT sure
well it depends on whether or not u have the S trim, or the I trim
personall i dont like the way those side markers look.
but smoked or clear side markers would be straight
Ive got smoked LED sidemarkers with NO writing. PM me and ill tell you where i was able to purchase from.
It says here...you talk like a *** and your s**** all retarded.
I vote no on those markers. The font is le poo.
I have those from e-bay. I had to cut the tab off and flip them 180 degrees so the current would flow right. LEDs are directional and the ones I got were put on wrong.... Just a heads up. They fit and look great once I modded them though :)
Weird creep.. Mine came with adapter pigtails and i plugged them in prior to snapping the light back in.. Tested each signal to make sure they got power and that was it. Did you purchase yours through thespeedline?
Weird creep..
Please Creepin, Thank you.
I don't think that they were from speedline. They where just like the stock ones though but neither one worked until I changed direction of the current through them... But no biggie thats why they made the Dremel now huh :)
