SGT VEGAS 843
Okay so I took my basic 4cyl 2005 mazda 6 to the dealership because it was cutting off at stop lights. initially they said it was the o2 censor and that they got a lean "code" but then changed their minds and replaced the fuel pump. the problem persisted and so i took it back to the dealership except they had permanently shut their doors for business. I went to the next closest dealership where they said they could not get it to code. The problem still persisted i took it back and they said i had to get some expensive service called an ISS service as it was the ethanol in the fuel causing my problem. He said it was clogging up the injectors. I paid for that service and for the transmission fluid to be changed as the car was also shifting roughly. I left having paid $338.05 for maintenance items. He additionally told me that they were not able to produce any codes after performing this service. Well my car problems persisted. I called back and said that my car was still acting up and I needed to bring it back in. I took another day off of work and took my car back to Stokes. The service guy told me that the maintenance item had helped to diagnose the problem and that it was my solenoid valve that was sticking. So they allegedly replced that or cleaned it not sure which. well it has only been 3000 miles and my car is starting to act up again. At the direction of the dealership i have been putting injector cleaner in my fuel about every 4th tank of gas.
what the car is doing specifically is that when in D or p the engine seems to be struggling for air or fuel. IT will idle slightly above 750 and seem smooth but then drop suddenly to 500 for a second and then back up to 750 -800 rpm range. It makes it feel really rough. kind of like when you try to start moving in 3rd gear. anyhow, as you can probably tell from this post I am not a mechanic but I feel as if the dealership is just not wanting to fix the item because it will be expensive. any ideas of what you think this problem may be or anything you have heard that you might think help me diagnose this situation will be much appreciated.
