noob coil over offset question (sorry guys)
Fresco
Contributor
So I have a 17x7 +38 rims, I want to run 215/45 17 tires on the P5, will I still rub on bc coils with camber plates, or should I just run 205/45 17 tires, I used that offset calculator website and it mentioned that it would fill the wheel well "by extra 12mm" I honestly have no idea what that means lol so input please guys
Youre wheels are an inch wider and are pushed out 12mm more than stock. This means that the total amount that your wheels stick out past stock is 1/2"+12mm.
If youre fenders ar rolled, you should be good.
If not, then a little camber or height may need to be adjusted.
