noise from rear right wheel.
Bijou-MP5
Contributor
2010 Mazda3 S Hatch
I don't know, when this happened, recently i am hearing noise from back.
It seems like something is stuck in my right rear wheel, It sounds like scratching, but i can't find anything that causes this noise...
maybe it's time for wheel alignment? or something serious problem with my car.
Anybody have or had same problem or know problem, help~
Re: noise from rear right wheel.
Check if the jack is tightened in position. Could also be a rattle caused by the screw (the one in the pouch with the wrench) supplied to install regular wheel in place of the miniature spare... You just have to check every possible option. Hope this helps.
Does the sound increase/decrease with changes in vehicle speed? How about when you depress the brakes? Possibly something stuck between the brake pad and rotor, or you may have bent the shield on the rotor a bit so it is scraping.
