new user needs help: grinding noise!
I just started to have the same problem with the front end noise.
just in the morning when it's cold out. Did you ever get it fixed.
The bushing problem is the rear sway bar bushing.
(cluck in the trunk). I've had them replaced twice in a year and it's coming back again.
The front end noise you are hearing is also the bushings. Mine too is only first thing in the morning when it is cold out. Eventually I will put some Energy Suspension greasable bushings up front too.
your problem is the "squeak" problem everyone pretty much has. It's a bushing issue, bring it to your dealer. The only thing my dealer has done is regrease it and it goes away. Has been away for a good month, but I don't doubt it will return.
