Ben@Toeldo
Greetings,
I recently stumbled onto a problem with my Unichip's toggle switch wiring. Its seems that a batch of Unichips made it into the market that have their toggle switches mistakenly wired. This was confirmed by a tech at Unichip.
My ECU RESET toggle is actually controlling my FUEL MAP A/B Toggle. The switches are mislabled. You can identify this problem by toggleing the ECU RESET toggle and watch to see if it triggeres the FUEL MAP LED. If the FUEL MAP LED flicks on and off when you trigger the ECU RESET then you have the same problem I do.
FYI
FYI
