New Toys for the 2014+ Mazda3
CorkSport
2010 Mazdaspeed 3
Authorized Vendor
All Mazdas!
2014+ Mazda 3 Axle Back Exhaust
You know you want to make your redesigned and refined 2014 Mazda 3 stand out in the crowd, and one of the easiest bang for your buck modifications is the new CorkSport Axle Back Exhaust.
UMj8L_DhyjZ1Np8xkNxoGSOe_ekueMecEOr6nqQPR-X4fgsa3u7s8zfMCTZWG2n75gAh9a0d1kERthdsAdx-uMOxyUz3g6xDqPFDjXT6BLY8x1YQi2z9ZTRNOg
Get added power and upgrade the look of your 2014+ Mazda 3 with the CorkSport Power Series Axle Back Exhaust. As a completely new vehicle the engineers at CorkSport were given free reign to design an axle back exhaust in the best way fitting to the graceful design of the Mazda 3.
The CorkSport Advantage:
Stainless Steel T304 construction with 80mm stainless tips for corrosion resistance and a clean stylish look.
Mandrel bent, true 65mm piping for increased flow and more power from your engine
CorkSport Service and Support: Receive a 2 year warranty, full color installation instructions, all of the needed installation hardware and knowledgeable telephone support
Order your Mazda 3 Axle Back Exhaust today. Only $549.
2014+ Mazda 3 Rear Swaybar
Remove the tendency to overpower the front tires under hard cornering and minimize traction robbing body lean with the CorkSport Mazda 3 Rear Sway Bar. The CorkSport Adjustable Sway Bar will compress the inside suspension, this effectively increases the spring rate on the side of the suspension which is compressed most which will give better cornering. With the Rear Swaybar installed you will increase cornering ability, minimize body roll, and gain noticeable handling improvements.
avsrFtYaBadie_45X0ryC2yCK4z0M7Sv2RmTl96hJ7dvI97sX4tNjvyLEcDuQlsLi7GRG01EX3O6FQO0cqdzFltVLYry3lnVzO327zVbO6rxycLma7Ywge902w
One piece design: CNC bent for precise fit and made from 28.5mm 4130 Steel
Polyurethane sway bar bushings: that include brackets fitted with grease fittings for easy servicing
Durable blue powder coated finish: can survive winter driving in areas where roads are salted for snow and ice.
CorkSport Service and Support: Receive a two year limited warranty, full color installation instructions, all of the needed installation hardware, and knowledgeable telephone support
Order your Mazda 3 rear Swaybar today. Only $209
That exhaust is on my list. I'm hoping to get the 2.5L intake first, once you guys release it.
It should be soon on the intakes, just waiting for the production to be completed.
-Derrick
On the 2.0 listing "In initial testing with the 2.0 Liter SkyActiv engine, the CorkSport Short Ram Intake netted peak gains of +5 HP and +6 lb torque at the wheels"
The dyno graph is for the 2.5 model.
-Derrick
-Derrick
Thanks!
Looks like the 2.5 isn't losing much of its power to the wheels. I'd be interested to get the exhaust together with the SRI for the 2.5.
I need to fill out the form. My 2.0L sedan is too quiet. So quiet I heard the gas sloshing around in the gas tank last night while pulling into the driveway!
Wouldn't be too hard to have a nice tip exposed with an aftermarket axle-back. There really isn't anything impeding the exhaust from coming out.
How about the back panel? I guess I'd have to take a good look at it to make sure modification of that panel isn't necessary.
