New Product! CORK SPORT Front Motor Mount Insert
I was wondering the same thing when I was checking those out yesterday...
I have had the first test set in my car for about 4 months. I swapped them for the AWR 70Duro mounts. The vibration level is slightly less than it was with the previous AWR mounts. No difference in install, the rear is still a pain.
So your saying the AWR 70's are a bit softer ?
I want to closest thing to stock, without the motor trashing around everywhere.
i have them on my car now vibration is minimal did notice a difference with them but i want to go harder
try these
http://www.mazdas247.com/forum/showthread.php?t=123654276
We have had great sucess with them. Our motor mounts offer best of both worlds. Helps eliminate wheel hoop plus transfers very little harmoics through the dash. Do a search and you'll see what others here are talking about.
plus here's a discount code you can use when checking out that way you can get them for only $61 shipped.
Discount code: MPFMM7
DIRECT LINK TO PRODUCT: https://www.secureplanet.biz/SLSP/ProductDetail.asp?idproduct=576&idCategory=
SLSPERFORMANCE said:
try these
$60 for a single mount is still more than $40 for the insert that does the same job.
Good to see another Vendor though.
Thanks for the info SLSPERFORMANCE, but if anyone had tried the corksport motormounts I'd like to hear your thoughts. The front insert is only 28$, so I might just try it out anyway.
OK, Eric, I bought one from SLS. I'll give a shot. (My front mount is SHOT).
the front is almost like a modding requirement on these cars even in stock trim, especially if you like to hit 2nd hard. For $28 you cant go wrong.
