New P5 Wheels from AutoRnD
Only the ones listed. I can't spend much time on these things. However I've listed only what will work.
Thanks, Rishie
eting_pro5 said:
doesn't the P5 typically experience rubbing unless you use the +48 offset?
if you do not want to role the fenders --- then dont go over a 17x7 with a +45 offset --- if you want to see how close a 17x7 +45 is --- i can take a picture :)
ps -- thats with a 215/40
you might have a little more room with a 205/40
with no rolling of the fenders
I have used the 17x7 +45, 215.40.17 many times and have only in few instances experienced rubbing on the passenger side I believe.. I know this to be a common issue. To run a better tire diameter would be the MP3 205/45/17. Either way I would be making a tire recommendation for each of these that would work for your vehicle.
I'll begin the group buy for certain wheels I do especially like. I just received some Enkei lightweight awesome wheels in stock today. I'll post pics by this weekend.
FYI, I have tokico HP and Espelir springs now with 215/45/17, 17x7.5 +48 Enkei RPF1. THese wheels are literally about 15lbs. It's sickening.
Laters, Rishie
chuyler1 said:
I'd like to see what these look like on a P5...
senrcorwin has them on his car. not sure if thats the correct spelling
peace
Rishie is extremely busy, like he said in earlier post the best method would be to get with either myself or dave. We both work for autornd and we are here to serve you guys.
ok, rishie mentioned enkei wheels coming in, any RPO3's coming in and what offset is their 18x7.5?
the b**** is I need an 18x7.5 wheel cause thats what tire size I have a hookup for....this makes things hard with a p5 trying to keep the budget as low as possible. (under 1k)
mountjonas said:
some wheels that are 7" wide can go with a lower offset.
You can go with a +45 on wheels, but why risk it with a fair selection of nice looking wheels with the ideal offsets. These wheels will also work on the Mazda 6 and the Mazda 3.
Those Enkei RP03 are available. I did not bring them in but I can. We will make a separate thread for this.
Thanks, Rishie
when i rub (215/40/17) -- its not the fender lip i hit -- but above it on the underside of the car -- it pretty far up (by the door) -- i was surprized it can go that far ----
They won't be super light. You only have one option for light and cheap, Rota. We've tried many times to offer those wheels but there's just not enough people at the right time.
I will check on the weight, I would expect 20lbs per wheel, less than the MS wheel.
As long as they're lighter than the stock RH's I'm stoked. LOL. Also, I'm looking to fit a stoptech BBK in there too, any idea what size spacers I would need?
hey rishie, how many buyers would you need for a rota roder to go through....idealy when I first started shopping for wheels the set I wanted the most was a set of 18" battles in bronze...sooo sexy....anyway what would it take to get these made?
