Hi all,
A few weeks ago, I purchased a CPO, 2022 CX-5 Signature with 2,500 miles. I'm very happy with the car, and it's much more comfortable than the GTI I'm coming from.
But, I do have some questions and concerns, and I'm not sure if they are common issues with easy fixes, or if they're just normal quirks with this type of vehicle:
- At highway speeds >60MPH, I find that I have to make many more subtle steering adjustments than my old GTI to stay centered in my lane. The steering tracks perfectly straight as best as I can tell, and all tires have even tread wear, but I feel the car sometimes unexpectedly try to veer or jump over in either direction, never aggressively, but just enough that I notice. This is with no heavy wind, so I suspect it's an issue with the stock Toyo tires (tramlining?)
- The driver side mirror glass visually vibrates when driving at highway speeds as well. I feel like it didn't do this when I test drove it, but a few days after purchasing, I found a more comfortable driving position and adjusted my mirrors to fit, and this is when I noticed it started. Passenger side does not vibrate at all, as far as I can tell.
- This may be an issue with my phone, but Android Auto always starts on a black screen, and I have to press the music or nav button to bring up display. Also, sometimes my music will start playing after starting the car, then immediately pause. After resuming music, everything is normal.
- When backing up into my garage, the frame rate of the backup camera will, consistently, significantly lower for a brief moment. It does not do the same thing when I back in to my spot at work.
- Is there a way to disable the "beep-beep beep-beep beep-beep" when exiting and closing the door with the car running?
- Is there a way to switch camera view without having to press the camera button beside the steering wheel? I find the button difficult to find sometimes at night. The manual says it can be changed with the commander knob, but it hasn't been working for me.
- Traffic Jam Assist (lane-centering up to 39mph) almost always will quickly move me out of the lane, even when the car is obviously controlling steering (green indicator), on straight roads. It even detects lane departure warning from its own steering mistakes.
Sorry about the long post. I've tried to research most of these issues, but could not find solid answers. My biggest concern is the difficulty keeping centered at highway speeds.
Thanks in advance!
Thanks in advance!
