new member just killed his car
If the rod is bent, then at TDC the piston will be at a lower point in the cylinder. The swept volume of the piston will still be the same, but the volume at the top of the compression stroke will be larger, meaning that cylinder has a lower compression ratio. Lower compression ratio = lower compression.
At least, that's the logical interpretation... there could be other factors I'm not aware of ;)
It could indicate the rod is bent but it could also indicate several other problems. I would think if a rod is bent enough to limit piston travel the piston would also be damaged. You could have a damaged piston and the rod could be either good or bad.
I don't think a compression tester is the best way to check for a bent rod, there are too many other factors that can affect compression readings.
Clifton
i saw a saturn hydrolocked, and its bent rod was the only damage.. it was rebuilt with no furter compliations, but you're absolutely right. rings coulda been blown right outa the lands, rings might have been sheered, etc. If it passes a compression check thats a great sign though, so its still worth doing. if it doesn't your only real option is to just toss it, or rip it apart and see how bad the rebuild is gonna be.
just got a call from the dealer, there is a hole in the block.
More to be updated as it becomes available
