Thanks for coming through on your deposit! Nobody doubted you, we just impatient.
Your install should be no problem. Boost guage takes like 20 min. SS is pretty easy too. Depending on what brand SS you have, you might have to bend or cut a little on the front of the exhaust heatshield beneath the shifter. You can also use spacers and longer bolts to move the heat shield down a bit. I think the TWM comes with these. I used a cutting wheel and just trimmed about 2 inches off the front (looks better than bending). If you don't already have them, you should throw in some Kartboy bushings & Corksport Bronzeoil Bushings while your under there. The Kartboys go in no problem, but the Bronzeoils require a little fitment.
