Need some info please...
Split6
2003.5 BlazYell MSP
I already have an Injen CAI and an MBC. Still have 2K to spend. Any advice on the best way to spend it(most bang for the buck) and then how much boost to run? Any help would be appreciated.
if you dont want to open the motor:
apex J/midpipe exhaust, dsms air fuel controller, smic, 9-10psi.
Downpipe and exhaust- 2.5" if you want under 300 horsepower, 3" if you want 300+ horsepower
Front Mount intercooler or upgraded sidemount
Electronic boost controler - to control boost with gear. With the above two upgrades you could run a nice psi through 3rd gear then drop it down for fourth or fith for increased safety
Front mounter mount (Rear if you want ever more stability)
If you plan to stay under 300 horsepower you could probably get all that. The 3" exhaust and bigger intercoolers will cost you more.
I wouldn't recommend the AFC yet only cause it's so new. The first 20 have allready been bought so I'm sure if there are issues they'll come up quikly. It does look like a promising unit though.
