prince igor
Hello.
i don't if i posted in the right section of the forum,hope it will be ok.I am in need in some advanced technical data regarding this engine.I am making a simulation for my diploma project and in order to complete this simulation I need some data.
Info that i need are the following:dimensions of the intake-exhaust valve,valve lift let's say from 5" to 5" crank rotatation(" = degrees),3-angle specification of the valve seat,turbochargher type (name,dimensions of inducer-exducer both for kompressor and turbine,injectors - flow....
I had found a manual for the Mazda 3 MPS but i was disapointed when I found that there are no info or drawings regarding the cross-section of the cylinder head (i can aproximate the dimensions of the intake-exhaust ports),the timing diagram,the dimensions for the intake-exhaust valve,the injector characteristics are only available for the NA engine not for the TC engine.
If some one can help me with some data,drawings,the help is very appreciated.
THX.
igor
THX.
igor
