need help with wheel bearings and or hubs
2006 mazdaspeed6 grand touring
The right rear wheel bearing on my 06 ms6 is bad, I can hear it driving around. Who makes a replacement wheel bearing and hub assembly for the all wheel drive cars? I'm taking the car out of town in two weeks and I don't want it locking up on me away from home.
I was planning a How To for this. NAPA Auto has wheel bearings for around $54 each. I recommend replacing both at the same time as they have both seen the same miles and terrain. You will need a breaker bar or decent impact wrench. The wheel nut is size 35mm. You will also need a pitman arm puller which you can rent from O'Reilly's Auto Parts. You will also need a 23mm wrench or socket for the bottom bolts on the wheel hub assembly. Other than that, you will need your regular sizes up to a 18 or 19. I will post a link when I make the thread. You can expect around $450 for both sides from a shop.
