Need Help with CX-5 Oil issue PCV
Part 1: Weird Dipstick reading
Bought a 2017 CX5 touring 2.5L Non-Turbo and driven a few thousand kms since. Full service history with Mazda, 135k km OD, appeared to be in great condition and drove well.
After purchasing I noticed the oil read just on minimum which I found odd as it had a recent documented service. So I topped it up to just over full. Over the next couple weeks I notced it seemed to have dropped slightly back to just full.
Recently I did full oil change with filter (around 4600-4700mls came out). I added just over 4.5L of fresh 5w40. I checked the level and it read just over minimum. After driving a few short km and letting car settle the oil still shows just over minimum and even days later hasn't changed. I made sure there is no oil leaking from sump or filter or any obvious spills on the ground anywhere.
The capacity is 4.5L, but with over 4.5L put in, the level still appears low as it did when I purchased the car. So I wonder is the factory capacity incorrect or is the reading on the dipstick inaccurate? Should I top it up to max or leave it?
Part 2: Oil issue PCV?
In addition, we notice the car seems to idle a little louder/rough for 30 sec to a minute when cold. I though this was maybe the viscous fan engaging and then disengaging, but I'm not sure.
With the low oil issue in mind I observed the car idling and it was smoking a bit. Fairly light, grey smoke, not sweet or blue. But the smoke was in timing with revving the car.
I followed my wife to observe it's behavior and it didn't really smoke much at all during a 5km drive. Almost not at all apart from while stationary a couple times during the start of the drive. With the car parked, I noticed glistening black on the inside of the exhaust. I wiped it with my finger and it was like wet, old black oil (I had just completed a full oil change). I wiped it away and while the car idled it seemed to accumulate a little more.
Weirdly, when we arrived home a few minutes later, the car was still not smoking and the exhaust seemed pretty clean, if not a little moist.
I feel like with only 135k km and a car that looks well cared for and with full service history piston/oil ring damage seems a little unlikely. After a little googling I began to suspect PCV, perhaps stuck open causing excessive exhaust gases to be forced out exhaust and oil consumption?
Any suggestions or advice greatly appreciated as we are panicking a little after spending our savings on this car that appeared to be in good condition.
Cheers.
Shouldn't you be running 5w20 syn oil? Loud idle on startup is normal, it's the fast cat warming, usually drops back to normal after 20-30 seconds.
ps: don't overfill the oil, half way between min/max is fine.
Upvote 0
Others on here have discovered that the timing cover weeps oil because the material used for a gasket is like RTV and wasn't let to set up before assembly. I have the same problem and was told the charge to fix would be @ $2100.00. Personally I'm keeping an eye on the oil and haven't seen any on the driveway. Since this was an assembly problem you'd think they would cover this.
Upvote 0
these engines are supposed to run 0W20
but if you're running that thick of oil, you need to wait longer for the oil to drain back before checking the level... do not ever check the oil immediately after shutting off the engine... oil in these engines drain back very slowly and takes more than 30 minutes to do so
Upvote 0
Hopefully u do not have the crack on the back of the head by cylinder 4 (furthest from belts). Several of th 2.5 turbo and non turbo had issues with bad heads that cracked. My 2018 cx-5 NA cracked and thankfully was still under warranty. It has run perfectly since Mazda replaced it.
Upvote 0
They said it was a 2017. There was no CD or turbo that year.
Upvote 0
Manual in Australia calls for up to 5w30. Very hot Summers and Mild winters.
Upvote 0
Like I said i checked it days later and still the same low reading. Also in Aus the manual calls for up to 5w30.
Upvote 0
I can recall a couple of times when I checked the oil and it was really low, but I know there was more oil in there... it seems kind of unreliable to only rely on the dipstick reading because for some reason the oil doesn't always show up the same on the dipstick.
I usually know how much is in it but if I want to make a careful check I wait overnight and make sure the car is parked level.
The extra noise right after start-up is normal, the system is try to heat up the catylictic converter to reduce emissions.
If you have too much oil in the engine it might smoke a little as it burns off the excess.
Upvote 0
Could be valve cover gasket leak or slight oil consumption
fine. but 4.5L is low.
cold start cat warmup. normal.
there is no low oil issue.. it just wasnt filled to full.
that is vapour/condensation, not smoke.
rain water inside the exhaust mixed with carbon deposits. normal.
Cheers.
your car is fine.
Upvote 0
That's insane! My local mechanic did it for $180 CAD with the gasket included.
Unless it's dripping down your engine block onto your alternator and belts I wouldn't worry about it too much.
Upvote 0
