B beaterp5 Member : Mazda protege5 Feb 19, 2017 #1 I did a atx to mtx swap, i have everything working and running great except the instrument cluster wont work, turn signals work, theres power to the cluster but none of the gauges are working, any suggestions?
i12drivemyMP5 <<<<<<< >>>>>>> Contributor : -- 23 CX-5 -- Feb 23, 2017 #2 Did you go with the manual tranny ecu? Does it need the manual gauge cluster?
B beaterp5 Member : Mazda protege5 Feb 26, 2017 #3 Im having the same issue, i did swap the ecu and mtx cluster, it gets power, turn signals work on the cluster, but no working gauges
