pydpypr said:I have the RF 15004. The power input conector on the amp is 1/0 awg. So after the 0ga. makes it into the trunk, iam supposed to reduce it to 4ga. even if the amps connector is for 0ga.? Won't the wire heat up if it is too small?
say the amp puts out 300x4. 1200 watts / 50% efficiency = 2400 watts input. 2400 watts / 14.4 volts = 167 amps input. say you've got 14 ft of 1/0 cable with 297 amps flowing through it (basing the T10001 on 1500 watts output at 80% efficiency = 130 amps). the voltage drop from the 1/0 cable would be .181 amps. 3 ft of 4 gauge cable with 167 amps flowing through it will drop the voltage another .232 volts. the wire will account for a .413 volt drop, which is acceptable (.5 volts being the most you would want). BUT keep in mind that music is dynamic, so you will never be drawing a full 297 amps. plus i seriously doubt you would ever push that T15004 to its full potential, unless you had it running subs.
